help with gfx card choice
The differences between the cards are very small.
The Inno3D card is definitely the best value for money from those 4 cards.
The other 3 cards are slightly overclocked, but you can easily OC the Inno3D card to the same speed.
The best one performance wise is the Asus. The one with the best value for money is the cheapest one, in this case it's the Innovision.
Thanks for that hwbot link Silverlight.
It really doesn't justify to pay 50% more for the Asus Direct CU II card if you're not going to run it off Liquid Nitrogen.
What's the warranty on the Inno3d? Can't find anything on the net, only numbers being thrown around on forums like 12 months or 3 years.
Asus and Gigabyte are the kings for warranty and after-sales service.
Inno3D is regarded as one of the cheaper brands, with HIS, Powercolor, etc.
