High capacity/lumen LED light backups
Those batteries are only 6V 1,3Ah batteries, while the Magneto uses 12V 4Ah LA batteries. They would not last
a long time between charges, one would preferably use at least 2 in parallel or even 3.
Are you sure? The last emergency lamp (not magneto) I opened had a 6V LA battery.
Those batteries are only 6V 1,3Ah batteries, while the Magneto uses 6V 4or 4.5 Ah LA batteries. They would not last a long time between charges, one would preferably use at least 2 in parallel or even 3.
Or like just search for more than 5 seconds to find higher cap 6V packages...
So they all just did 2hrs on duty. Now measuring 16W across all 5 during recharge
