High Ping - Tracert results please help me understand
Razeth
Hi Guys,
Lately I have been having really bad ping with online gaming. Can you please help me understand this tracert results as I dont know when it means the exchange is congested or the problem is caused by ISP.
Here is the results
Tracing route to mybroadband.co.za [41.203.21.137]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms Billion.400G [10.0.0.2]
2 306 ms 307 ms 252 ms 41-133-112-1.dsl.mweb.co.za [41.133.112.1]
3 208 ms 234 ms 259 ms te1-1-0.511.cpt-ipc-1.mweb.co.za [196.28.178.202
4 258 ms 237 ms 201 ms 197-84-3-2.cpt.mweb.co.za [197.84.3.2]
5 214 ms 224 ms 219 ms TenGigE0-7-0-2.12.cpt-p-2.mweb.co.za [196.28.178
.114]
6 204 ms 196 ms 172 ms tengig0-0-0.cpt-pr-2.mweb.co.za [197.84.4.165]
7 194 ms 172 ms 177 ms mtn-pp.cpt-cinx-2.mweb.co.za [196.28.178.142]
8 252 ms 256 ms 249 ms 196.44.0.75
9 227 ms 181 ms 165 ms rb-cr-1.za--ct-cr-1.za.mtnns.net [196.44.31.128]
10 192 ms 180 ms 163 ms jh-dca-2.za--jh-cr-1.za-a.mtnns.net [196.44.0.22
1]
11 131 ms 111 ms 91 ms ge4-0-0.gw17.jnb6.za.mtnbusiness.net [196.30.1.3
7]
12 147 ms 152 ms 176 ms vlan9.hr3.jnb6.za.mtnbusiness.net [196.30.156.13
6]
13 311 ms 312 ms 281 ms core-router1.jnb2.host-h.net [196.30.213.108]
14 315 ms 325 ms 304 ms core-access-switch1-vlan1001.jnb.host-h.net [41.
72.136.53]
15 273 ms 263 ms 248 ms mybroadband.co.za [41.203.21.137]
Trace complete.
Thanks and much appriciated
Yup, hop 2 is very high and that's the first hop to your exchange.
Sorry, but you have a congested exchange :(
traceroute to mybroadband.co.za (41.203.21.137), 64 hops max, 52 byte packets
1 dsldevice.lan (192.168.10.1) 2.196 ms 1.861 ms 1.660 ms
2 196-210-148-1.dynamic.isadsl.co.za (196.210.148.1) 27.334 ms 17.424 ms 16.411 ms
3 196.38.72.125 (196.38.72.125) 18.142 ms 18.668 ms 18.245 ms
4 196.35.115.136 (196.35.115.136) 20.716 ms 23.073 ms 19.532 ms
5 core2a-ctn-gi0-1.ip.isnet.net (168.209.2.6) 21.612 ms 47.338 ms 25.565 ms
6 168.209.2.130 (168.209.2.130) 26.672 ms 26.465 ms 36.257 ms
7 41-208-29-210.mtnns.net (41.208.29.210) 47.602 ms 19.115 ms 17.640 ms
8 196.44.0.75 (196.44.0.75) 18.542 ms 18.937 ms 18.978 ms
9 rb-cr-1.za--ct-cr-1.za.mtnns.net (196.44.31.128) 42.243 ms 48.501 ms 41.192 ms
10 jh-dca-2.za--jh-cr-1.za-a.mtnns.net (196.44.0.221) 42.841 ms
196.44.31.97 (196.44.31.97) 43.313 ms 42.396 ms
11 ge11-0-0.gw2.jnb6.za.mtnbusiness.net (196.30.1.22) 52.809 ms
ge4-0-0.gw17.jnb6.za.mtnbusiness.net (196.30.1.37) 170.672 ms
ge11-0-0.gw2.jnb6.za.mtnbusiness.net (196.30.1.22) 56.296 ms
12 vlan9.hr3.jnb6.za.mtnbusiness.net (196.30.156.136) 48.564 ms 59.504 ms 70.021 ms
13 core-router1.jnb2.host-h.net (196.30.213.108) 58.303 ms 48.162 ms 62.781 ms
14 core-access-switch1-vlan1001.jnb.host-h.net (41.72.136.53) 54.986 ms 43.879 ms 59.673 ms
15 mybroadband.co.za (41.203.21.137) 59.492 ms 48.758 ms 46.719 ms
Thanks guys. Guess I will have to wait for telkom to fix it in 3 years.
Ok so I took the plung yesterday and went with a 4mb business dsl account. Everything was working great in the beginning but it seems like p2p downloads have been deteriorating. I was happily pushing 400kb/s and now i'm sitting at 1kb/s on both dl and ul. What going on? I thought p2p wasnt shaped at all?
Oh and are my pings normal? How do people get low pings?
Tracing route to mybroadband.co.za [197.242.89.170]
1 37 ms 22 ms 15 ms 192.168.11.1
2 9 ms 10 ms 9 ms 105-236-7-65-esr-lo.mtnbusiness.co.za [105.236.7
.65]
3 25 ms 25 ms 25 ms 41.181.221.254
4 25 ms 26 ms 26 ms tb-dca-2.za--qux-c.za.mtnbusiness.net [41.181.19
8.188]
5 25 ms 25 ms 25 ms unc-cpt-1.mtnns.net [196.44.18.8]
6 25 ms 26 ms 26 ms 196.44.31.106
7 25 ms 26 ms 26 ms nl-ha-2.za--rb-cr-1.za-a.mtnns.net [196.44.0.121
8 25 ms 26 ms 25 ms africainx.cinx.net.za [196.223.22.47]
9 49 ms 49 ms 53 ms CORE.GP-CN-HET-MEE-1.TO.GP-MR-VOD-MEE-1.DFA.P2P.
10G.za.africainx.net [41.84.12.151]
10 50 ms 49 ms 50 ms 41-66-132-242-f2.HET001-CPE-1-to-GP-CN-HET-MEE-1
.africainx.net [41.66.132.242]
11 52 ms 51 ms 51 ms core-access-switch1.jnb1.host-h.net [197.189.193
.1]
12 57 ms 54 ms 54 ms 197.189.193.62
13 51 ms 51 ms 52 ms 197.242.89.170
Trace complete.
Connection Speed 4096 kbps 511 kbps
Line Attenuation 12.0 db 3.6 db
Noise Margin 16.3 db 29.2 db
Oh, I live down the street from my exchange if that helps.
@Krazye:
It seems like your WiFi connection to your router is poor. Use an Ethernet cable if you want better pings.
