Hi fellow humans.
A follow up on a previous thread I crated HERE
As with everyone, desperation have now kicked in. Previously I was only planning on installing a inverter in my Baldwin apartment, with no panels and was looking for a "silent" inverter. Well none are really suitable.
The plan now is to get approval for a ZOZO type hut in my garden (didn't want to do this to not loose space, but hey....POWER)
In there I will house a inverter and battery/s. This will also allow me to attach solar panels to the roof. With the size of the ZOZO I can install 2 panels at most (std 2m x 1m panels).
Because of the the Vmp on the solar, I can only go for a 3 KW (24V) unit. The best in that is the the small 3 KW Growatt units.
The drawback is that it is only a 3 KW unit, and more than that the batteries are insanely expensive, and the selection rather limited.
Hubble AM-2 is around 20K each, I see other options but they are all "off brand".
So for 5 KW storage I will need to spend R40K just on the batteries. The equivalent 54V battery starts at just over R 22 K for a different brand, and R30 k for the Hubble.
So to get the same storage I will need to spend more on a 3KW system in total.
I have been looking for other options, getting 4 small panels with a similar footprint of the generic 45V panels. But by the time you get a small enough panel, they swop to 24V, defeating the intent.
I found CNBM 6P-325 325W High Voltage Poly Solar Panel, with a Vmp of 74V. So 2 can get me to 148V and that will allow for a 5KW 48V inverter and in turn a "cheaper" battery.
Yes, there is the potential problem of a broken panel, and I'll loose all solar, but no problem buying a extra unit and keep it in storage (in the new ZOZO I have to install)
Does anyone have any other ideas? my general load is small, about 300 W constant. I would prefer to have 640W panels, but sacrificing generating power for a 5KW inverter is a trade off I am willing to make.
EDIT: I check CNBM's website, and they don't have this panel listed.... so will have to investigate more, but please and other ideas will be greatly appreciated.
