Had a similar problem last week, turned out to be a faulty network switch. Connect the two machines directly with a cross-over cable - think you'll need to assign fixed ip's on the same sub-net. Another source of trouble may be a faulty network cable, re-plug all network cables and make sure they are properly seated. Lastly, check the network cards.
He can access using ip with \\ip so faulty cards are not likely. Layer 3 is working which means its higher up
Thanks guys,
Feedback...:
Tau1z : I ran \\ipaddress on my desktop & the shared files of my desktop come up...( yay )
IRG: I dunno how to fiddle with my registry
Labratza : as for \\ipaddress...how do I map my network Drive, I am pretty sure that this could work...
Though....if my desktop is not showing on the network group, How am i going to access
" map network Drive "
I also tried " add network place " did not work...
Vero LAnd : I put a password on my laptop.....No difference....
SO teh problem is...: there is something blocking the desktop to appear on teh network.
Not the fire walls...what else can it be....?
"Map network Drive..." if I can access this, that would great
ahh...any other things to try out ? Netbio, Permissions, regedit ? ? ?
Thanks guys
I've seen this several times, causes were faulty network cards, routers and cables - causes intermittent and puzzling results. You have to replace each one of these components to eliminate the problem. I've seen this again just two weeks ago. PC, printer and lappy connected via router. Can ping everything from both, no show on workgroup, can't search for \\pcname either. After I replaced the router no more problems.
Again, see his access..
Thanks, I attempt Mapping the drive,
\\server\name
I recieve an error That " THE NETWORK PATH CANNOT BE FOUND/"
Frustration level has now been upgraded from mere migrane to binine tumor...
Thank you Microsoft.
I am wondering if u have a DNS issue then? try ping the machine using machine name and see if it resolves.
