Only today or it does it all the time?Hi
As per the topic, I put a sim into my phone, worked for a few seconds and died. How are they blocking the sims being used in phones etc?
Thx
Ok, I tested it now, it indeed doesn't work in other devices, seems they recently implemented this as I was able to use service on a tablet before.Always, and they have made it clear the sim will only work in pre-defined devices
Edit your build.prop on nokia7 to display 4g and test againThe mystery deepens, or maybe is solved?
I put the sim in my Nokia 7 plus - and instead of showing "4G" or "4G+" as it normally does, it shows "LTE" and its working like a baby. How, why? What is the difference between 4G and 4G+ versus LTE?
