Hi guys
I received my goods from Prophecy yesterday, and thus I was looking forward to slapping together the new PC. The assembly went without a hitch, but the problem came when I did the first POST. It just hung on the BIOS Splash Screen. No keyboard activity, nothing. After a lot of random hardware exclusions (disconnect HDD's, DVD-ROM, swap RAM, run one stick, etc etc) I finally got a POST. I thought I miraculously got it working! ROCK! So after starting windows installation and progressing up to the HDD formatting, the PC was supposed to reboot. And it hangs again. And no amount of hardware changes could get a successful POST again (I got tired and I need to sleep and stuff). I also cleared the CMOS by removing the battery in case that would help. It didn't
So after doing a quick check on the gigabyte site this morning (from work) I see that my BIOS version does not support my CPU! I need the very next BIOS version at least (I have F7, I need F8a). http://www.gigabyte.com.tw/Support/Motherboard/CPUSupport_Model.aspx?ProductID=2629 But how the hell do you flash the bugger if you cant POST! Should I just hope and pray I get a POST again? Also, I don't have a floppy drive since I didn't think it would be necessary. So I need another CPU (that is supported, borrowed from a friend) and a floppy drive to sort this out?
HARDWARE:
GA-P35-DS3L (motherboard)
E8200
Mushkin 2x1GB
2x320GB Western Digital HDD
ATI 2900XT (my old card, which works since I can see the splash screen)
LG DVD-ROM/Writer (i think its the LG one)
And uhmmm, thats it i suppose. Any help would be greatly appreciated
HARDWARE:
E8200
Mushkin 2x1GB
