ichigo
1. Never install windows updates unless they are important driver updates and security updates. Some updates have been reported to slow your pc down a lot.
2. IE8 and IE9 is good as Microsoft claims, but Mozilla Firefox and Chrome are way better for protection and for internet browsing/downloading and speed.
3. What antivirus/internet security program do you use? and don't say AVG/Norton Antivirus
they slow down PC's a lot. I would using COMODO Internet security or Avast.
Comodo blocks unwanted internet/program access and deletes viruses quickly, also tells you how much bandwidth each program is using.
4. You should also scan your PC with malware bytes, Adaware and Spybot Search & Destroy to see if you got spyware/malware on your PC.
5. You can also defrag your hardrive using Smart Defrag it will free up space and may improve your PC Speed slightly.
6. Use a registry cleaner
7. Delete the Temporary Internet Files, cache and the download folder for your browser (has temporary files) > C:\Users > Your Username
8. The best way to run a safer/cleaner PC is simply to be a conscientious user or to use Linux based operating systems
Links to the programs needed
Browsers
Mozilla Firefox
http://www.mozilla.com/en-US/firefox/new/
Google Chrome
http://www.google.com/chrome/index....&utm_medium=ha&installdataindex=homepagepromo
Anti Virus Programs/Internet Security
Avast
http://www.avast.com/free-antivirus-download
Comodo
http://www.comodo.com/home/internet-security/free-internet-security.php
Microsoft Security Essentials (Scans Slow)
http://www.microsoft.com/en-za/security_essentials/default.aspx
Script Blocker
Script Blocker addon for Firefox
http://noscript.net/
Spyware/Malware
Malware Bytes
http://www.malwarebytes.org/
Adaware
http://download.cnet.com/Ad-Aware-F...-10045910.html?part=dl-lavasoft_products_noTP
http://fileforum.betanews.com/detail/Spybot-Search-Destroy/1043809773/1
Defrag tool
Smart Defrag
http://www.iobit.com/iobitsmartdefrag.html
Registry Cleaner
Comodo Registry Cleaner
http://system-cleaner.comodo.com/
PC Optimizer Pro
http://www.pcoptimizerpro.com/download.aspx
CCleaner
http://www.piriform.com/ccleaner
Cleans out temporarily files, cache, history, cookies, fields; even has a registry cleaner that is safe, friendly to use and doesn't do any damage. Oh, and it's completely freeware. You can also whitelist cookies you want it to keep.
Feel free to update the list and criticise
Browsers
Mozilla Firefox
Google Chrome
Avast
Comodo
Script Blocker
Spyware/Malware
Malware Bytes
Adaware
Defrag tool
Smart Defrag
Registry Cleaner
PC Optimizer Pro
CCleaner
