Stefanmuller
Hi There
I just got the HTC Hero on Wednesday on a upgrade, and I must say, Great phone!
There are still a lot of things I have to figure out, and as I read the "Tips&Tricks" thread here on mybroadband, I can see that most people are still trying to figure out how everything works. I would have posted my question in that thread, but it has been inactive for about a month now.
The main issues I have is the following, and if someone can help me, I would really appreciate it
1) The alarm clock, although set correctly, does not go off. I set the alarm for 7AM this morning, and although my phone is not set on silent, the alarm never went off. The date and time was correct as well as the "day of the week" option and the alarm selected as "on". I checked this after I eventually woke up, and set the alarm to go off in 2 minutes just to check. Out of the 5 times I tried, it only worked once or twice. This is a big problem, as an alarm is a critical function for me. Any ideas, or apps that work for you?
2) I still don't know how to "close" applications, so that it doesn't run in the background. Take for example the internet browser. There is no "close the application" button or function, so if you return to the home screen, the browser is still running. So it often happens that 15 apps are running at once in the background. I read the tips&tricks thread, and downloaded Taskiller, so I just kill all the programs I don't need. I also put an icon for Taskiller on the home screen that looks like a litte Robot with a number in the middle showing the amount of apps running and the memory used. So with a click of a button, all tasks can be stopped at once. Is this the only way to completely close applications?
3) Rom upgrading. My phone came with the following software, ROM and Kernel (whatever all these mean)
Android version: 1.5
Kernel: 2.6.27.8dd6deee
Build: 2.73.1104.4
Software: 1.0.0.A6288
Which of these can/should I update and how? I noticed that some applications need android 1.6, so can the version be updated, and also, is it safe/recommended to update the above?
So far I am very happy with the phone, I just need to at least fix the alarm clock, and make sure I am running the latest software/ROM/versions.
Build: 2.73.1104.4
