B Broucek New Member Joined Jan 16, 2010 Messages 9 Reaction score 0 Feb 17, 2013 #1 Hi, I have Huawei E220 modem which I would like use on 8ta 3G network. Anybody knows if 8ta sim card will work ?. Thanks
MickeyD RIP Joined Oct 4, 2010 Messages 139,095 Reaction score 432 Location Nelson Mandela Bay Feb 17, 2013 #3 /seconds Use the Mobile Partner interface and create a new 8ta profile.
J JAM007 Senior Member Joined Mar 17, 2011 Messages 668 Reaction score 29 Feb 17, 2013 #4 im using a 8ta 3G sim in a Huawei E220 and got Mobile Partner Software and its working fine. Create a New Profile eg: Internet / APN: STATIC / ACCESS: *99#
J jacksonc Well-Known Member Joined Jan 12, 2010 Messages 126 Reaction score 1 Location Jhb Feb 17, 2013 #5 You can simply screate a new dial up network the old easy way
Telkom Expert Member Company Rep Joined Jun 2, 2011 Messages 2,246 Reaction score 2 Feb 18, 2013 #6 Broucek said: Hi, I have Huawei E220 modem which I would like use on 8ta 3G network. Anybody knows if 8ta sim card will work ?. Thanks Click to expand... Hi The 8ta SIM will work with the E220. Does it have the default Mobile Partner software on it? Thank you 8ta
S sajunky Honorary Master Joined Nov 1, 2010 Messages 13,120 Reaction score 276 Location JHB Feb 18, 2013 #7 It works, but make sure that firmware is upgraded to support 7.2Mbps. Some early models are only 3.6Mbps.
NeonNinja Neon Resident Joined Nov 22, 2009 Messages 26,466 Reaction score 4,418 Location Neon World Feb 18, 2013 #8 Yes. MDMA or Mobile Partner. Download the firmware. I use the E220 with MTN and 8ta.
