huawei portable wifi external antenna?
DANNLER
hey guys so i have a huawei portable wifi running telkom. Signal is okay always getting 2 bars of 3g. I noticed on the back of the router there is some sort of antenna plug. So if i get an external antenna that fits, would it be worth it?
And what kind of antenna must i get also where can i get it?
Thanks in advance.
Unfortunalty i dont have premission to post attachments.
Its huawei E5332
Mine looks different. If you open the one that i have at the back then its got this small round plug with a pin in the middle
Ah okay, then what router is a good one i can get, mind you that i dont have a high buget
