Huawei S7 Slim OTG USB cable
MyWorld
Wes Transvaal
So, after a long while I finally decided to make me one, and I must say I should have done it very long ago.
Here is the instructions:
http://www.androidtablets.net/forum...ng-usb-external-hard-disc-flash-memory-5.html
You will need this app to mount flash drives:
http://android.gval.biz/
http://android.gval.biz/download/Q5_USB_Memory_Manager.apk
I have tried a USB mouse, keyboard and flash drive. The mouse is a bit buggy, the keyboard works perfectly and the flash drive also works 100%.
Be sure to apply this fix to get the USB host mode going on the S7 Slim:
http://mybroadband.co.za/vb/showthread.php/390589-S7-Slim-g-sensor-fix-Linux?highlight=S7+Slim
How long did it take you to make the cable? Also can u put pics of ur cable up please
Ok i read all your links.... Only part i dont understand is your last link but maybe thats because its too early in the morning.
On a side notes, do u have tasker working on ur s7 slim?
Here is the cable finished:
The reason for the tape is that there is a minute piece of wire sticking out, I'm miffed that I did not get it properly sealed before applying the putty.
:mad:
The last post is a script you can run that fixes a few bugs with the S7 Slim.
* G-sensore fix, fixing the sensors of the tablet
* Enabling USB host mode on the tablet, and a few other fixes.
[[NB]]DO NOT APPLY THE BOOT IMAGE[[NB]]
You can Google USB host for S7 Slim and there should be other ways to do this as well, this is just the easiest. In windows you can just download and run the script, choose the options you want patched and presto.
How long did it take u to make the cable?
would you be willing to make more?
at a reasonable price?
Buying the cables is going to cost a bit, what makes it cheap is if there is already waste cable laying around. I'll get a price on cables and post here what it will cost to make it and then you can compare it to buying the factory made thing from Ebay.
Give me a while and I'll post the prices here tonight.
ok cool thanks
ebay links too if you can
are all the OTG cables the same?
How will i know if a cable is otg? I have a draw with extra cables. If i find a male micro usb to female usb, how will i know if it will work?
Also are you guys running the stock froyo os on ur s7 slim?
ok cool thanks
No. On mini/micro plugs on the phone/tablet end, you need to short pins 4 & 5. On other plugs you have a problem. I ended up buying one off BoB. I wish MyWorld had started his experiments earlier.
Okay, just got back from the PC shop and was I surprised!
I looked at the cables, saw it would be way too expensive and chatted to a friend there.
"Show me the connection you are looking for."
He runs behind the counter and presents me with this:
I was sceptical at first, but bought is anyway, much easier to mod if I need to.
Plugged it in, and PRESTO! It actually works! Picked up the flash drive straight away and the USB keyboard also works on this!
So, head on over to your nearest PC shop and show them that picture, ask them to get you one!
EDIT:
The shop here still have a bunch of these, PM me if you want one and then we can arrange something.
They are asking R45-00.
Postage is in the range of R30-00 (will have to make sure) if someone needs me to send them one. I'll test each one before sending it off to make sure it works.
ill be down for a few
anyone else want on the centurion area? save on shipping etc?
but let me check if i can find them here first - will go check this wknd
Eh, I got the same question as rodga. It may not be your job but if you want to make a quick buck MyWorld:
How much will you charge for me to bring you my S7 Slim and you get it all to work? :o
I'd rather have someone do it properly than me trying it and breaking everything. :)
*edit*
Damn, this thread moved fast while I wasn't looking and didn't see everything that was written since about the nice adapters and whatnot. That will teach me for opening up a thread, walking away and posting later.
Ok i mite be able to get that adapter from a chinese shop in Durban, downloading q5 is easy since my S7 is already rooted.... Only problem is that patch....
I dont wana brick my tablet... So i need step by step instructions...
