iBurst Omni Antenna
InusB
Kempton
I am looking to buy an iBurst Omni Antenna in the Randburg area, can someone please let me know where I will be able to get one.
Have you tested to make sure it helps? My iburst works better without the omni...
Thanks r00igev@@r
Hope it works, I have long USB cable connected to the modem at the moment, if I put the modem high up against the wall my signal goes to 100%, if not its between 60 - 90% depending on the way the wind blows. So I'm going to give it a shot.
Thanks r00igev@@r
Mine is on the curtain railing. :D
The signal strength stayed on 100% and the torrent I was busy with went from 1 - 20kbps
Pictures??? Mine is on the balcony balustrade.
If my internet is working when I get home, I will post a pic for you. :D
I am thinking of doing something like this:
I got a proper Omni from Poynting mounted on the roof. It was a bit expensive - R800 with 15m cable but it works. My reception is from 30% without antenna to constant 100%. iBurst still slow during the day though.
