M Mahomed29 Member Joined Oct 26, 2021 Messages 10 Reaction score 1 Nov 10, 2021 #1 Hi, I am considering investing in a solar solution. I have come across Lithium batteries by Lithium Batteries SA. Any information, experiences or recommendation on these batteries will be appreciated
J jvniekerk_it Member Joined Jan 18, 2021 Messages 12 Reaction score 8 Nov 10, 2021 #2 Had mine for 8 months now 229 cycles with no issues. Ensure you have a compatible inverter as it uses CAN bus protocol only. (Victron,Growatt,Sunsync,DEYE) Does not communicate with any axpert inverter variant I know of,mine is kodak not compatible,. Can work fine without communication as it has its own current limiter and temperature control switch built in, will only get it charged to about 98-99 percent without communication as lithium does not move much in terms of voltage as lead and gel does. In terms of delivery I got my battery within 2 days of ordering. https://lithiumbatteriessa.co.za/collections/built-units/products/48v-100ah105ah-5-1kwh-tested-5-2kwh-usable-40a-lifepo4-lithium-iron-phosphate-wall-mount-solar-ups-battery-rack-mount?variant=39397565202599
