HaNsA do you remember changing any other settings besides those in the RouteSentry instructions? Or any settings on your router page? What router are you using BTW?im using 2 IS accounts atm...one international the other local only...and its actually only some sites that are timing out...eg google is working fine....might just be a IS problem
Well, if I use the International dialup connection like normal on it's own while the router is in bridge mode then everything is fine. No timeouts or anything that I've experienced. But running local and international together with RouteSentry seems to cause trouble.I'm having the same thing, but I really don't think RouteSentry is the problem. Last Sunday my international went down and I was experiencing exactly what you describe. Thursday it came right again and now its disconnecting again. I'm also running webafrica prepaid. I've contacted them and they say everything is fine, as does telkom. So now I am lost.
And now I have the same problem all of a sudden! Never had this problem before
Router:Telkom 100WR
International: WA SAIX Prepaid
Local: WA 10GB IS
What changed recently?: I hard reset the router this morning.![]()
think it is the INTL connection, mine is down too.
How do you know it's loading through the local account? Are the lights on the little monitor icon of the local account lighting up?
Tracing route to www.l.google.com [64.233.167.147]
over a maximum of 30 hops:
1 * * * Request timed out.
2 43 ms 86 ms 104 ms 196.38.73.217
3 47 ms 45 ms 47 ms curp4-rba-gi2.isdsl.net [196.38.73.114]
4 46 ms 45 ms 56 ms dsl1-rba-gi0-1-50-curp4-internal.isdsl.net [196.38.73.109]
5 46 ms 45 ms 141 ms cdsl2-rba.isdsl.net [196.36.80.162]
6 45 ms 53 ms 45 ms 196.36.80.165
7 657 ms 754 ms 653 ms 168.209.0.242
8 722 ms 658 ms 652 ms 168.209.100.42
9 1250 ms 1492 ms 1048 ms 168.209.246.9
10 1449 ms 1496 ms 2207 ms 195.66.226.125
11 * * * Request timed out.
12 * * 1199 ms 66.249.95.146
13 1414 ms 1824 ms 3036 ms 216.239.46.48
14 2928 ms 1775 ms 2721 ms 72.14.232.53
15 * 2429 ms * 64.233.175.26
16 * 2863 ms 1892 ms www.google.com [64.233.167.147]
Trace complete.
What happens when you change your setup to be as if you only have the international account? That is the router is in PPPoE mode and the international account details are put in there.
