iPhone 7 plus keeps disconnecting bluetooth and wifi
Inn3rs3lf
Johannesburg, South Africa
Anyone else found a solution to this?
Have an apple watch, and it keeps losing connectivity with my phone, even if its 1m away. Same thing with the wifi, albeit not as often.
I have reset all networks, and unpaired/paired the watch, and same thing...
After iOS10 update?
My Bluetooth issues were resolved by turning off Bluetooth and then hard resetting (hold power and home until it reboots).
So maybe start there.
If still no luck do a Reset Network Settings. You'll need to enter keys for all your wifi again.
Unless that's what you meant by having Reset it and didn't mean the router etc.
Bluetooth & wifi...both on 2.4ghz. You sure there isn't some kind of interference?
