K and T wall bracket?
Hi Guys,
Sorry I know this is a bit off the topics but not sure were else to ask this question. I'm busy installing my WUG kit against the wall on the side of the house(No proper place to install on the roof). Problem is that the roof comes probably a half meter over the wall. The pole I'm gonna use is 6m galvanized steel. How will it be possible to over come the roof? Saw some K- and T- bracket made for heavy duty but have no idea where to buy them(I live in Cape Town). What do you guys think? any ideas?
Thanks!
Try scoop.
The following bracket will move the pole about 47cm's from the wall
http://www.scoopdistribution.co.za/product_info.php?cPath=39_71&products_id=660
I think that is the biggest you get.
The next thing you can try is to take one of the roof tiles off close to the wall and put a hole through it, then run the pole through the whole and it will be closer to the wall. But that depends on your roof and you :)
