Kitchen tap loose
Snyper564
Gauteng
Renovations continue.
Had two of these fitted yesterday
Left the silicon etc on the basins to set overnight so I did not touch the area till this afternoon.
The one turn from sink to sink tap/spout not sure what its called is loose
Is this a screw it tighter thing (plumber) or a fault (tap)?
Just seems something a chick would ask. Like, why don't you just check if there is a screw/fastener loose, or if somethings broken?
Are you serious?
I didnt install it... The instructions dont indicate there is anything to fasten to adjust this...
I legit dont know if these are a fasten it mechanism or a product fault.
ITS BRAND NEW there are two one is loose one isnt...
Why silicone if I may ask.
When I replaced my mixer for my island, I bought a tool set at the plumbing shop. Not difficult. And no leaks.
no the basins were siliconned not the taps - i didnt fit the taps bringing me back to my original question is this a loose screw as the thing is solidly placed its just that part thats loose on one not the other
  • Haha
Reactions: rh1
Are you serious?
I could reply with the same tone...
Are you serious?
Forward... just ask the bloke that installed it to come fix it, if he can't, he'll tell you if it's faulty.
I could really with the same tone...
Are you serious?
Its also Saturday and I like to understand things a bit better hence the question.... product/plumber fault...
  • Like
Reactions: rh1
There is a brass stud which screws into the bottom of the tap, then a washer type thing and rubber washer in the same shape. This hold the tap against the marble/slate/countertop. This held with a small nut. The tool is quite cheap and makes it a easy job to tighten the nut. Other wise a spanner, but very awkward to tighten.
thats rock solid spout is loose
If the spout is loose there can be basically 3 problems. The problem is this new type of taps I don't know how their fittings/mechanism work and if its the same as the old.
On the old style one problem can be a missing washer/o-ring. There are normally 2. Second problem is it may not be pressed down/inserted deep enough. Third problen it may not be screwed in tight enough.
