I'm on my 2nd ADSL modem router , just installed it now , 1st was hit by
lightning , Ive searched everywhere but I cant find a lightning
protector for telephone lines. so if you cant buy it - make it , so i
made my own , as we only use 2 wires i only needed 2 fuses , i used a
rating of 0.2 amps per fuse , the lowest you can go is 0,1 amps but the
shop didn't have any. so hopefully if lightning hits the telephone lines
it will break the fuse as its such a small rating. the front plug was
"harvested" from a old modem.
http://buju357.blogspot.com/2010/12/lightning-protector-for-telephone-lines.html
