mac os9.1 problem
kronoSX
Capetown home to gang stars
Is there anyone that have any disc like these lying around,even a recovery disk.
The file system of this g3 powerbook is messed up ,folders missing from the drive and files here and there scattered all over the place.
Also will diskkeeper4 repair this:confused:
I have a Tiger PowerPC drop-in disk if you want to buy it, R300 and you can come fetch it, it's an original.
I'll have a look in my box of tricks. I should have it somewhere. Probably got 7 and 8 lying around too :D
What Powerbook G3 do you have again? How about OsX? :)
ok that will be fine i guess:DI am a windows man so what ever you say i will believe:)
g3 powerbook
ok even if i download those 19 image files from apple,what would i do with them to build a iso to burn it in windows 7 to boot in the mac.
the osx..will it work on this 400mhz powerbook.And how will i get it from you.
I also have a tiger ppc disk lying around, if u pay postage its urs...
g3 powerbook
Hope you downloaded 7.5.3
http://en.wikipedia.org/wiki/System_7#Available_versions
also get the 7.5.5 update
http://download.info.apple.com/Appl...merican/Macintosh/System/System_7.5.5_Update/
System 7 is really old and not supported anymore... It's best to get OSX since you can install new apllications like firefox if you have OSX.
Don't know how to burn the files to CD though.
OS X works on a 400mhz G3. How much RAM do you have?
Try to get 10.3 - it will run nicely. 10.4 will too if you disable Dashboard to save some RAM.
Which one is it, the Lombard or Pismo? Some resources at the awesome Lowendmac
The Pismo is the **** by the way.
http://lowendmac.com/pb2/g3-guide.html
http://lowendmac.com/ed/moore/08cwm/best-os-ibook-powerbook.html
http://lowendmac.com/pb2/pismo-powerbook-g3-2000.html
http://lowendmac.com/ed/moore/08cwm/compleat-lombard-guide.html
PowerBook G3 (Firewire 400/500MHz, Pismo, M7572
