You can opt into YouTube's HTML5 http://www.youtube.com/html5youtube = flash. that's why. flash kills the battery and makes CPU run hot.
No java and flash on iPad and iPhone!
I also get less than 3 hours on my 11" Air. if you have a 13" you should be getting more.
Need to investigate deinstalling the flash as per this thread.
Problem is I bought it overseas and I don't have proof of purchase to show them - guess I'm pretty screwed.
Why?I have however since I bought the laptop only charged it when it was completely drained until full.
Lithium-ion polymer batteries pack in a higher power density than nickel-based batteries. This gives you a longer battery life in a lighter package, as lithium is the lightest metal. You can also recharge a lithium-ion polymer battery whenever convenient, without the full charge or discharge cycle necessary to keep nickel-based batteries at peak performance. (Over time, crystals build up in nickel-based batteries and prevent you from charging them completely, necessitating an inconvenient full discharge.)
Anyone have a macbook air could tell me how much battery life they are getting?
I am getting around 4.5 hours on around 50% brightness; browsing the web and watching some youtube videos.
Mine will lasts 6 hours with the 80% brightness, it's enough for the daily using...
