Macbook Pro - Clamshell Repair or Replacement
muhammed.abad
Centurion, Gauteng
Accidentally dropped my macbook and dented the bottom corner. Looking for an affordable replacement casing somewhere in PTA (preferable) or the Johannesburg area.
I've seen replacement clamshells on ebay, but not sure how reliable those sellers might be.
Try weFix, though I doubt you'll get a replacement clamshell in SA at an afordible price if at all.
Chances to get a cheap solution from a store is next to 0. Try and find on OLX and Gumtree for dead non functional MacBooks or even eBay. eBay might take much longer but there's more options and it's going to be cheaper.
