azzietj
Hi everyone, I have a Mecer 5kva inverter that gets charged using Eskom mains and no solar panels. I installed it in early 2019 and it worked perfectly during load shedding and could even last 18 hours. However, since the beginning of 2020, it barely lasts 45 mins. Electricians have said I need to replace the 4 gel batteries with lithium but that’s another 30k I’m not prepared to fork out yet. They also tested the charge of each battery and said there’s no problem with them but couldn’t explain why they were discharging so quickly.
I know nothing about electrical work and inverters so I’m not sure if there’s a setting I can change in the inverter or what to do now. I just want this system to last through load shedding as it did in the past. If anyone is able to assist I would really appreciate it!
