Mikrotik VPN help
siphongwenya
Hi All,
I've setup a pptp vpn on mikrotik and I can connect without a problem.
The problem is I can not ping the PC's on the lan.
I want to connect via remote desktop when connected.
I would also like to use the 3 public ip addresses s was given by the isp to forward to local PC's.
I've got 3 vlan's setup.
Hi Sipho
Just a few things to check regarding this(from my experience)
Make sure that you use port 1(Internet) to connect the LAN, if you are using VLANs on the PCs, tag the port.
IP addresses of the PCs must be in the same subnet as the Mikrotik and use that Internet port as a gateway.
I hope that helps.
