Mobile Application help plz
pjoub06
Hey, I got a sony ericsson k850i last night. I am having trouble finding an application that supports googletalk and skype and allows you to make voip calls with them for free. Fring does this but it a symbian app and doesnt work on the k850i. You guys know of any apps?Thanx :D
You probably tried it but in case you didn't, there is a version for the SE K850. I was sure that they have both java and symbian applications although I could TOTALLY be wrong.
Thanx for the reply guys but i have tried/looked at all those options. Many apps support IM but I want to make actual calls using 3g...S60 has hundreds of these apps. My phone has SIP but I cant find a single app that allows me to call to skype and gtalk for free and is java based. minifring is for java and it doesnt support VOIP :( Nimbuzz does support VOIP for java either. Skype mobile forces you to pay...I will be rather pissed off if there isnt a program like fring for SE k850
Ok i've officially decided java VOIP is non-existent except for skype's application and that you have to pay for...But thanx for the help guys
