Rouxenator
Dank meme lord
Sometime they cram things in the engine bay like your ABS modulator, so that you don't end up cramming your engine bay in another car's boot.
Actually one can handle the boost and fueling for a "turbo system", as you put it, just fine on a Carb fed car with no engine management software...It's just more of a hassle.
The sad part of it all is that these manufactures does not provide the necessary skills to their after sales people. They are just as dumbfounded when these new gadgets break.
One should have the option to switch off all unnecessary units.
Wait till these cars get older. Everything starts to break and nobody to fix it or it cost an arm and leg to replace:twisted:.
Yipee more money for the manufactures.
It's a long-term conspiracy.
And so we generate more garbage by the day.problem is, it cost money to train the mechanics/techies.
Another problem is - in the older cars you could strip some components (for example, your windshield wiper gearbox/engine assembly) in order to service these - nowadays these are factory sealed and need be replaced with a full unit.
It is also easier (and quicker) just to replace the electronic component(s) [expensive] instead of tracing the fault [cheaper].
