MTN Fibre data usage problem
pdhbo
I have 20mbs Fibre from MTN cappped at 100GB. For three months now I run out of cap after about a week or ten days. MTN tell me they cannot help since they do not yet have the capability to get a URL report. They can only get a usage report which shows the data usage by time. There is also nowhere where one can go and see one's balance of data left at any particular time.
The funny thing is that the data usage report shows significant data usage when there is actually nobody at home.
Does the CPA not require that MTN provide a detailed invoice of where my data was used- ie a URL report?
Their attitude is "Oh well- your data cap is up - wait until next month -we cant help you identify where your data went but please pay your account promptly- and by the way you can't cancel your contract."
The c&^% Huwaei modem they supplied also does not allow for any logging or reporting data usage of any sort.
Most of my data is used to watch HULU which uses 0.65GB per hour. If I watched Hulu 24/7, it would take 6.4 days to use 100GB. I watch at most about 2-4 hours per night (and not every night) which should be around 2GB per night taking me to 40-80GB per month. I have no way of identifying where my data is going!
To make things worse they took a month and a half to get the fibre working and charged me for that time!
Anybody have any ideas what I can do to try and resolve this issue?
On what devices are you using it? Have you made sure that your WiFi encryption is good (WPA2)? Are you running Windows 10? If so, have you disabled the peering over internet for windows update option? (Settings > Update & Security > Advanced options > Choose how updates are delivered > Only check local network PC.
Have you considered installing some network bandwidth monitoring tools on the devices? Windows 10 has it built in, Settings > Network & Internet > Data Usage. Your android and iOS devices should also have it built in.
The ISP does not and should not be providing you with any more info than amount of data consumed at various times.
Why dont you just try turning off the router when you are not home?
True what he says, according to POPI they are not allowed to do that
