hislordship
Hello
Just out of interest, how many MTN subscribers here have noticed that the voicemail diverts can't be cancelled? You enter the ##002# or ##62# (or other code) or use the phone menu to cancel the diverts, it comes up with a message that it was successfully done, and when you check the status of the divert, it's still active to voicemail (08314xxxxxxxxx).
Why is this an issue? Well, if you go roaming overseas, you can't deactivate your voicemail, so when you don't answer a call, you pay for a call to the foreign country and then one back to South Africa.
How many people know about this, and how much is MTN scamming out of people because of this?
ALL the other networks allow activating and deactivating of diverts as you choose, just not MTN.
And yes, I've tried it now on several numbers (even bought another prepaid one to test, plus on friends' phones).
I've brought this up with MTN, but not sure if they're going to do anything about it - they are investigating.
Does your phone do the same?
