Mweb or vox data pro ?
Psyonide
Mweb are offering me a complete VoIP solution with new handsets , pabx and a mpls VPN with cisco routers
Vox data pro are offering the cheaper and easier crystal vox solution setup with quantum gateway attached to my existing pabx
Between the 2 ...
Mweb or vox data pro?
Anyone had experience with the 2
firstly, be careful of getting locked into contracts. you should either try the service out for 30days, or look at alternatives such as www.1cloud.co.za
Firstly try to avoid any long term contracts, all of the equipment bundled offerings involve contracts. If your PBX is still good, buy yourself a gateway and choose any provider you you want on a monthly basis. How many lines do you want on the gateway ?
Be awear of this if you port your numbers to any VoIP provider ! The provider may offer you service on a month to month basis but if you have ported your numbers to that provider, regulation states that you cannot port again for 2 months ! So choose wisely
I would not suggest VOX or Mweb but rather Euphoria.... we have switched to them from VOX and they are quick to respond and call quality is great.
