N00b needing help with IPTraff/RRDTool installation :(
MeNeZ
Hi,
I really need help getting RRDTool to work to use for network monitoring, I literaly have about an hours worth of experience using Linux and have a million guides open but I think Im going about things the wrong way...(Im installing remotely and dont have additional software packages available on CD so I need to download and install whatever is needed...
When I try execute the RRDTOOL I get the following:
[root@system rrdtool-1.4.5]# ./configure
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking target system type... i686-pc-linux-gnu
checking for gcc... no
checking for cc... no
checking for cl.exe... no
configure: error: in `/root/RRDtool/rrdtool/rrdtool-1.4.5':
configure: error: no acceptable C compiler found in $PATH
So I imagine I need to install gcc, dd & cl.exe? I've looked on some FTP sites, most are down and the others are huge and this 68mb download of gcc-4.6.1.tar.bz2 is going to take 1 hour and 44 minutes to download so you can see why I want to make sure Im doing the right thing first... :erm:
I was also looking at Debian, should I install that??
You do not mention what distro you are using, but if you want to build packages manually then you are going to need a compiler, hence gcc.
Do a search for gcc or install the developers packages, that should include gcc.
Thanks for your reply, Im installing it on ClearOS. I beleive it is its own Distro??
I'm busy downloading GCC now
yum groupinstall "Development Tools"
And look into iptraf as well, will be much easier to manage than something you had to compile yourself.
