Need some help from the tech savvy please: PS3 wireless thingamabob.
Kerrrang!
Ok, my current setup has always been my PS3 and PC both in our TV lounge, both connected to my Sammy, but we've decided to move the PC back upstairs so that my wife and i can alternate between viewing TV/gaming and using the PC.
Question: is there a way to now have my internet connection on my PC upstairs connect wirelessly to my PS3 downstairs?
I don't have a Telkom line, using E220 HSDPA USB modem on my PC. If it's possible, what can i use, what should i buy and how hectic is it to set up?
Will i still be able to play online since wireless is generally worse for online gaming than wired?
Thanks!!
dude
you need to share the internet connection on the PC but bear in mind you need a wireless adapter on the PC and the PS3 should pick it up but distance will be a prob NOT a good idea
Will a wireless router not do the job? For example, link a wireless router with a cable to PC, and then stream internet connection downstairs to my PS3?
Yep. My cousin does the exact same thing. And for the exact same reason as well. Its a sign - lol.
I would rather set up a wired connection with a crossover cable. much more reliable. I tried wireless, but the distance was too far, >20metres I think, and I couldn't move the router.
Thanks for the tips.
Another question: my PC would be almost exactly aboe my PS3 (one floor up), so when a wireless router states indoors it's good for 100m, does the siglan go through the walls or does it go via the open spaces of the house, ie through the living room, up the stairs, down hallway etc?
What type of wireless router should i look for for best results?
Difficult to say as there are so many parameters. I use a Netgear 834GT but the best would be to get one of the newer types with two antennas
and turbo modes.
Like these examples (Key points in red)
802.11a/g Indoor Dualband Access Point (DWL-8200AP)
Here is another but no gigabit lan.
http://www.sybaritic.co.za/store/product_info.php?products_id=18076
For Business-Class Environments Secure/Manageable
Dualband Operation
108Mbps Turbo Mode
High-Speed Wireless Connectivity
Operable as Access Point or Wireless Bridge
Advanced Security Schemes
Solid Plenum Metal Chassis With 802.3af Power over Ethernet Support the
DWL-8200AP is a business-class 802.11a/g dualband access point that provides secure and manageable dualband wireless LAN options. With wireless speeds of up to 108Mbps and dual high-gain dualband antennas, this access point provides optimal wireless coverage in both the 5GHz 802.11a and 2.4GHz 11g frequency bands. Enclosed in a plenum metal chassis, the DWL-8200AP adheres to strict fire codes and ensures complete safety. For advanced installations, this access point has an integrated 802.3af Power over Ethernet (PoE) support, allowing installation of this device in areas where power outlets are not readily available.
KEY FEATURES
Dual 5dBi High-Gain Dualband Antennas
Up to 108Mbps Turbo Mode *
Dual Ethernet Ports With 802.3x Flow Control
Multiple Operation Modes
802.11i (WPA2) With AES
64/128-Bit WEP Data Encryption
Dual Port Ethernet Connection With 802.1q
http://www.billion.com/product/wireless/BiPAC-7800N-11n-ADSL2-Broadband-Firewall-Router-Gigabit.html
BiPAC 7800(N)
(802.11n) ADSL2+/Broadband Firewall Router with Gigabit Ethernet Switch
Experience super fast broadband connectivity with the ADSL2+ and FTTH multi-service gateway! The BiPAC 7800(N) series is an all-in-one ADSL2+/Broadband Router that offers users the flexibility of multiple Internet connections and expanded wireless coverage. All this is offered while maintaining high-speed broadband access via ADSL2+ or through an Ethernet WAN. The integrated draft 802.11n Wireless Access Point ensures the 7800N offers faster wireless speeds (up to 300Mbps) while two built-in antennae effectively search for wireless signals. The BiPAC 7800(N) automatically adopts the optimal connection to deliver smooth, constant signal reception even if obstacles are present. The BiPAC 7800(N) series is equipped with a second Ethernet WAN interface, which can be used to connect to an external broadband modem. This unique feature frees users to add fiber-to-the-home (FTTH) services when they become available. Users can easily enjoy highbandwidth applications such as High Definition IPTV services without changing their home network. A robust Firewall is also built in to provide protection against hacker attacks while the Quality of Service feature prioritizes queues and traffic for applications such as music downloads, online gaming, video streaming and file sharing.
Do some more research and good luck.
To give an example. As a test to see how the latest "PS3 media server" program performs on my PC I set up my PC DVD drive as a shared device, popped in a DVD, Gladiator 720P, and streamed it via the "PS3 Media server" program to the PS3 via wireless with DTS 5.1 sound via optical out to my Home theater. It worked fine but eventually something made the dvd stutter. Watched about a half hour before it happened tho and when I stopped the DVD player the PS3 still played for another 5-10 minutes before the buffer emptied. That is with the "Now due for retirement, getting old Netgear". There is much faster and better wireles routers/modems today.
The PS3 wireless spec meets the IEEE 802.11g specs, so its wifi g and You will only be able to stream at a maximum of 54mbps.
There are some devices that can improve the PS3 wireless speeds further. If money is not of concern then pair some of these wireless N devices.
1) Wireless-N Router like the Netgear DG2000 or other http://kb.netgear.com/app/products/model/a_id/2334
2) Wireless N gaming adaptor (makes your PS3 think it's wired) via ethernet http://www.techgadgets.in/peripherals/2009/10/trendnet-wireless-n-gaming-adapter-launched/
Other even better solutions?
See this here:
The NETGEAR HD/Gaming 5 GHz Wireless-N Networking Kit WNHDEB111 enables super-fast file transfers at the highest possible Wireless-N speeds, making it an ideal solution for network gaming and streaming HD videos. By utilizing patented metamaterial antenna technology, the WNHDEB111 offers a speed and range far surpassing the old Wireless-G standard.
By operating on the less crowded 5 GHz frequency, wireless connections are stronger and faster. View larger.
Easy Setup
The WNHDEB111 kit includes two access point/bridges, preconfigured to securely connect to each other. Setting it up is as easy as connecting one access point to your router/gateway, and connecting the other to your networkable device, such as your XBox, Playstation, Wii, TiVo HD, Slingbox, digital set-top boxes, NETGEAR's Digital Entertainer HD, Apple TV, network attached storage, and more. Setup is easily and securely done with a simple "Push 'N Connect" feature using Wi-Fi Protected Setup (WPS), which eliminates the need to remember or input security password keys. It automatically configures to access point or bridge mode depending on the type of Ethernet enabled device it connects to.
To add another HD Bridge to your HD network, the NETGEAR 5 GHz Wireless-N HD Access Point/Bridge is available.
http://www.netgear.com/Products/Entertainment/WirelessHDGamingKit/WNHDEB111.aspx
Netgear HD/Gaming 5 GHz Wireless-N Networking Kit +R1456.00
http://www.expansys.co.za/d.aspx?i=169080
Description
For high-performance wireless network gaming and multiple HD video streaming
More wireless channels, less interference and better connections using 5 GHz Wireless-N band
Automatic Quality of Service (QoS) ensures lag-free gaming and jitter-free HD streaming
Works with Xbox™, PlayStation®, Wii™ , TiVo® HD, Slingbox™, digital set-top boxes, NETGEAR's Digital Entertainer HD, Apple® TV, network attached storage (NAS), and more
Connects to any existing router/gateway and Ethernet ready device
Automatically adjusts to the needs of Internet, voice, video and gaming applications (QoS)
Wirelessly connect new devices easily and securely with Push ‘N’ Connect
No need to remember your security password
Supports wireless “ad-hoc” mode for wireless LAN peer-to-peer gaming
Support multicast point-to-multi-point HD video streaming
Automatically configures to access point or bridge mode
Package Contents
Two (2) 5 GHz Wireless-N HD Access Point/Bridges (WNHDE111)
Two (2) stands
Two (2) Ethernet cables
Setup CD
Two (2) 12V, 1.2A power adapters,
Warranty/support information card
http://forum.blu-ray.com/showthread.php?t=99378
https://www.expansys.co.za/p.aspx?i=145419 +R1600.00
http://www.d-link.co.za/dap-1522.php +R1200.00
http://www.expansys.co.za/p.aspx?i=179784 Netgear DGN2000 RangeMax NEXT Wireless-N ADSL 2+ Wireless R1200+
http://www.take2.co.za/electronics-trendnet-wireless-n-gaming-adapter--4369408.html R621.00
Happy hunting.
Thanks, got it sorted. Went with the Netgear (single antenna) but performance is fantastic - very impressed!
