Neotel and Wireless Networking?
Foosit
Hi all,
Please bare with me through this long and tedious post. This is my dilemma...
All I want to be able to do is:
A) Share my internet connection via wireless to other devices (namely my XBOX 360 and Macbook Pro).
B) Share files/folders via wireless to other devices (as specified above)
Problem:
The Neotel Prime device allows for one to make telephone calls (which is a must) and to access the internet. However, it is not a wireless access point. On the other hand, the NeoFlex option allows for a router and a wireless access point, but there is no telecom option with that package. So NeoFlex is not an option for me. So that leaves me with internet and a phone, but I cannot connect more wireless devices to it.
I have just recently installed Windows 7 and love the "virtual routing" capabilities thereof and I'm still finding my way around it. So far I am able to share my internet to my other devices quite easily, however I haven't been able to share my files through it. Which brings me to my first question:
1) Can one use the Windows 7 "virtual router" to share files/folders to another platform other than Windows 7 (such as my Mac)? And if so, does any one know how??
2) Also I would like to share files to my XBOX via the media centre. Is this also possible using the windows 7 virtual router?
The problem with the above is that the Windows virtual router is set to encrypt using WPA2... the problem? My 360 wireless card only supports WEP and WPA. Next question:
Is there a way to allow windows virtual router to use WEP or WPA encryption instead of WPA2??
I have also looked into the option of setting up a 3rd party 3G Router (a standard router won't work as neotel is a wireless internet device). D-link makes such a router and basically it will allow me to do everything I want to do... at the expense of R2200 odd.
It would just seem a waste to have to resort to that option when the Windows virtual router seems to work fine. I'm just not sure if it's able to pull off all the networking requirements I need it to (sharing files and net to my 360 and Mac). To the naked eye it doesn't seem like a complicated need, but after much searching, it seems to be!
Any advice, help, words of wisdom or anything would be greatly appreciated!
Thanks in advance!
Fabio
Consider the following setup (will be doing this myself next year):
~ Neotel Lite for phonecalls
~ Neoflex for internet
I also use my phone a lot and find it a pain when I'm on the net and then the phone rings, I get disconnected.
Hey there, thanks for the reply.
Yeah I have considered that option but it adds up to quite a hefty monthly bill. Seeing as though I'm only on the 2.5 gig Prime service, I don't really want to be paying TOO much more than that. Last I checked the cheapest NeoFlex bundle weighed in at R499 (for 5g). Coupled with the Lite for calls - R99. That's just your base, then you still have to cover calls...
At the moment with the 2.5g I pay R399 - which is decent.
BUT! After more scouting I did find this! http://majornelson.com/archive/2009/10/28/xbox-360-system-update-wireless-adapter-wpa2-support.aspx
Which explains a downloadable patch for the 360 that enables WPA2 support for my xbox...
Now only question remains.... file sharing between my "server box" running Win 7 - virtual router and my 360 and Mac... need to find a nice howto somewhere... :)
Set your router to be DHCP off... give it the same IP range os the ICS does.
leave the other pc's on DHCP (from your PC with ICS)
should work, worked for me... but i changed a few more things but this basically helped.
Thanks mate!
Hugo
