Netflix not working on Android box?
RVR
Durban
I've never really had Netflix on my X96 box or the Mxq one but I tried to install it (also a older version) because the new Netflix versions aren't compatible
Anyways, I'm able to enter my email and password but I keep getting
"Netflix can't reach server - 2" every time...
And it's not my network
Any advice?
Any advice?
Easy fix, buy a NetFlix certified device - stay away from devices, that say, "Do not upgrade apps" they going to break some time, and you will need to buy a new box.
I got it working, thanks though.
If you want to use the latest version of Netflix on non AndroidTV devices, download it from the APKPure app store and install from there, it's a split xapk and has better compatibility for lots of devices.
Also install DRM Info app and check that all your devices at least support Widevine L3 DRM otherwise Netflix won't work at all. Netflix also blocks old app versions from streaming or force you to update, so always use the latest version.
