Hi
Looks like the battery in my Nokia 920 has died
is their anyplace i could purchase a replacement other than Nokia directly
tried Vodacom but they don't do them
ian
Thanks for the Info
Will Order from them as soon a sI make sure it's the Battery that's dead.
Either that or the Phone's not charging the Battery hard to tell as I can't get the thing to switch on.
Might take it down to Vodacare tomorrow see if they can test it.
Thanks again
Ian
I'd say ~R200 is worth the risk for a phone like that. It'll probably take a month or so for the battery to reach you though. You won't get it in SA for anything close to that price.
Thanks for the Head Up
I brought it to a Shop in the Centurion Mall
Guy their reckons he can source battery. Had a call today saying the Phone should be ready tomorrow
Looking forward to finding out if it is the Battery, or as i suspect the Motherboard has gone
Will find out tomorrow
Ian
