Numerous reports about iPhone 15 Pro overheating
Hanno Labuschagne
Journalist
Staff member
Some of the first owners of Apple Inc.’s iPhone 15 Pro and Pro Max are complaining that the new devices get too hot during use or while charging, a potential setback for the company’s flagship product.
The gripes have spread across Apple online forums and social media networks, including Reddit and X.
[Bloomberg]
Would like to know how they can fix this with a software update without sacrificing performance in the process.
Sofar I heard about a software patch that bricked the phone, the overheating, bluetooth problems, the iphone too easy to break. and so on.
As for overheating yes when gaming, but then also when charging. Due to the design it will overheat, which is a big problem. How to fix it? The phone will have to be throttled via a patch. Yip it will be made slower, much slower. The Iphone heats up by upto 45-50 celsius. Which is well hot.
So the problem seems the casing, lack of vents, the sim card slot taking the space, and too many other options.
Apple is working on the Iphone patch to throttle it thus let it run cooler.
Does remind me of the Note 7 issues with batterygate, that ended the entire note 7 product line.
The phone is also the easiest iphone to break if bent or you accidentally sat on it.
Have a look
Meh. Will be fine. Apple will fix in a jiffy if there is anything to be concerned about. They look well after their posh sheep.
/looks skeef at Xiaomi.....
They will release a patched version, called iPhone 16, available in stores this time next year. At least people get the opportunity to beta test for Apple.
You are that guy that drives a 2010 116i just for the BMW keys and then try to make fun of people who can't afford a M3.
Besides that’s it’s a stupid childish argument that maybe had some merit in 2010.
All the top dog flagship Android devices cost the same as an iPhone, like for like.
Buy the brand/platform that works best for you.
It’s a phone, hardly anything to measure one’s dick over.
