Partition problem URGENT
Is the one that Windows wanted to format definitely the data partition? Have you tried running chkdsk?
Sounds like your active partition has been moved to the new 8GB. Hopefully your system partition is OK, try fixmbr, to correct your active partion. Also try run a repair....
