jphegers
Does one get charging cables for cell phones that last longer than a couple of months and where can you find them?
That is not the problem the cable comes away from the usb plug that goes into the phone.All my OEM cables last for years.
I am not accusing you of poor cable treatment, but I do believe that cable etiquette is important. Grasp the head, not the wire, when putting it in or out. Get a cable holder or tape the cables to your cabinet to prevent them moving around, falling to the floor, and being stepped on.
You still need a charging cable to connect the wireless charger.some phones allow you to wireless charge then you don't need charging cables![]()
That never works for me.Grasp the head, not the wire, when putting it in or out.
But they're less likely to wear out.You still need a charging cable to connect the wireless charger.
Bought one that only charges for 15 minutes and they told me they don't replace cables so I have to buy a new one again lolThose R60 cables at Cash Crusaders are pretty decent. Used to buy them on TA but Cash Crusaders one's are just as good.
^ This, I havent touched the cable that I have connected to my wireless charger in years.But they're less likely to wear out.
I need a cable that has greater protection where it enters the USB head because i am on a 24/7 oxygen concentrator and on my bed most of the time and use my phone constantly so looking for something strong.You still need a charging cable to connect the wireless charger.
Oh wait, charging cables...
Yes thank you will get hold of Takealot tomorrow appreciated.Did you look at the ones in my Takealot link? Has exactly that extra protection:
Same.All my OEM cables last for years.
My kids and wife on the other hand brake theirs in quick time cos they pull and bend however they want.
Forever I guess. The only down side is that you can't be on your phone while they are charging.Maybe under my circumstances it will be cheaper on the long run to get a wireless charger.How long does a wireless charger last?
You can always use a headset or speaker phone.Forever I guess. The only down side is that you can't be on your phone while they are charging.
