Each vessel has two modified KLT-40 naval propulsion reactors together providing up to 70 MW of electricity or 300 MW of heat, enough for a city with a population of 200,000 people. It could also be modified as a desalination plant producing 240,000 cubic meters of fresh water a day.Another modification will be supplied by two ABV-6M reactors with a capacity of around 18 MWe (megawatts of electricity). Also, 325 MWe VBER-300 and 55 MWe RITM-200 reactors have been mentioned as potential reactors to use for the floating nuclear power station.
In case anyone 'floats' the idea of the Russian Nuclear Barges:
Solving our water and electricity problem. Sounds like a win win to me.
Hmmm, power ships... Perfect solution for Luthuli House relocation.
It is a no brainer if a powership can generate power in a more cost efficient way than you can.He believes powerships can deliver power at R2.00 to R2.50/kWh which is considerably less costly than Eskom’s open-cycle gas turbines that run at a cost of up to R3.00 to R4.50, depending on the diesel price.
The powerships mentioned in the article uses gas or diesel.But it may cost another R1 000 000 per kWh to clean up the radiation leaks afterwards.
Russian nuclear technology cannot be trusted.
But those are very inefficient, don't think that Eskom can afford the fuel.
They also don't produce much power.
It would appear as if the powerships are self-sufficient and no additional cost for fuel is needed.Karadinez operates and maintains its own plant and typically enters into agreements for two to five years.
