Powerpoint help
marine1
A black hole in the universe - JHB
Hey guys I almost never use this but need some help.
I have 200 files, JPG's that were originally a PPT presentation but then saved them individually as JPG's to edit.
Now I need to create a new PPT presentation with the edited JPG's
How would I do this?
Use photo album as it auto stretches each picture to the slide size
Open PowerPoint
Create new blank presentation
Go to "Insert" menu
Select "Photo Album"
Select "Insert picture from: File/Disk"
Point to the location where your JPEGS are saved.
Add all the pictures you want.
Re-arrange in correct sequence.
Select "Create"
Modify to your own liking...
