Problem connecting Nokia 6110 Navigator using Linux
Tassidar
Leeds, UK
Hi all,
I seem to have problems getting my Navigator connected on linux
Using wvdial,
tim@Tim:~$ wvdial nokia
WvDial<*1>: WvDial: Internet dialer version 1.56
WvModem<*1>: Cannot get information for serial port.
WvDial<*1>: Initializing modem.
WvDial<*1>: Sending: ATZ
WvDial Modem<*1>: ATZ
WvDial Modem<*1>: OK
WvDial<*1>: Sending: ATE0V1&D2&C1S0=0+IFC=2,2
WvDial Modem<*1>: ATE0V1&D2&C1S0=0+IFC=2,2
WvDial<*1>: Sending: AT+CGDCONT=1,"IP","Internet";
WvDial<*1>: Modem initialized.
WvDial<*1>: Sending: ATDT*99#
WvDial<*1>: Waiting for carrier.
WvDial Modem<*1>: CONNECT
WvDial Modem<*1>: ~[7f]}#@!}!} } }2}#}$@#}!}$}%\}"}&} }*} } g}%~
WvDial<*1>: Carrier detected. Starting PPP immediately.
WvDial<Notice>: Starting pppd at Fri Feb 15 14:42:17 2008
WvDial<Err>: Warning: Could not modify /etc/ppp/pap-secrets: Permission denied
WvDial<Err>: --> PAP (Password Authentication Protocol) may be flaky.
WvDial<Err>: Warning: Could not modify /etc/ppp/chap-secrets: Permission denied
WvDial<Err>: --> CHAP (Challenge Handshake) may be flaky.
WvDial<Notice>: Pid of pppd: 6023
WvDial<*1>: Using interface ppp0
WvDial<*1>: local IP address 10.62.238.232
WvDial<*1>: remote IP address 10.6.6.6
WvDial<*1>: primary DNS address 196.207.40.167
WvDial<*1>: secondary DNS address 196.207.40.165
The cellphone icons change from 3G to 3G with dotted arrows (indicating connecting), however the dotted arrows don't turn solid.
Obviously, there is no data throughput.
Any ideas?
Hi
Wondering if anyone dad any luck with this issue? I would like to know if it's possible to use this phone on Linux before getting it.
Yeah, I got it working, and after that it worked pretty consistently.
You're easiest way to get it to work will be to look for Tax_Tux's wvdial.conf located on this forum. He gives pretty much all the options, and you can modify it to suit your purpose. It's actually pretty easy to use or pm me, and I will send you the file (if I can find it as it has been a couple of month's since I last used Linux)
Good luck.
