Problem Printing through Router setup as an Access Point
Ice2Cool
Dbn
Hey guys,
Needed some help please. I have a router which I am using as an access point upstairs in my house. It is connected via ethernet to my main modem router.
The problem I am having is that I cannot print to my wifi printer from this AP. However, when Im connected to the main router, I can print just fine. I believe this is probably a NAT issue, but there is no setting on the AP to change NAT settings. Is there any other method for me to sort out this issue? Maybe Static Routing? I have no idea how to set up static routes if that would solve it - please let me know!
Cheers!
There will be a setting on the AP to set it to bridging mode. When you do so, disable DHCP for the AP.
Should work then.
