LG RH7624W (and in general) is CRAP...
Yes, i also bought an LG RH7624W a while ago, and then the DVD read/write stopped working
. Local repair shop had it for 3 months and then said it will cost R1600 to replace laser (supplied by LG)!!!! How stupid! My LG Home Theater system also stopped reading DVDs and even ORIGINAL music CDs won't play.
I purchased a Taiwanese/Korean (?) cheapie (R399) DVD player from Cash Crusaders, which reads any kind of disk, USB sticks and SD cards, with full 5.1 Surround Sound and optical audio output. Works 100% so far...even DVD-RW and +RW disks.
I now use the LG Home Theater as an amp...which is also crappy as you only have preset audio options (3D, Matrix, Movie Theater, Soft, Classical, etc) but no individual bass & treble control. So sound quality is not very good, but that is actually a total different post!
The writer i managed to get working by opening up the unit and vacuuming and blowing the dust and stuff out, and fiddling with the laser arm. I know...not very technical! :wtf: Now i can write DVDs from the hard drive, but also still cannot play back any DVDs???? even ones i just burned with the unit??? It also still does not read any other disks...CDs, rental DVDs, nothing. When i got it i could write on DVD-RW and +RWs, but that i still cannot do even though it writes normal DVDs. This would suggest that it is not necessarily the laser itself that is faulty as LG tells me, but an alignment problem, which i am sad to say is out of my technical expertise to fix. So if anyone has experience or instructions how one can re-align the laser head it would be greatly appreciated!
I also will not EVER BUY ANY LG PRODUCT EVER AGAIN!!!!!!!!! Maybe we can start a "LG, its NO GOOD" campaign...
