KirPlunk
Hi guys,
Been ages and its awesome to see Mybb has grown to what it has become.
If you had a guy come install something that has a set of wan hardware, fo incoming, subscriber line or WISP basestation. What is the norm out there? Surely not 19" ers? And what are you left with? To put the router/switch/poe/dvr on the floor or if you had space on the desk.
And if you were given no choice by the company installing the utility hardware for for you that it either goes up on the wall or we cant offer workmanship guarantees. Would you think it is a modest enough prerequisite for it to be easily accepted by future subscribers?... Based on out idea of a wallmount installation methodology. I used pattex red doubsd tape to stick the white ubiquiti POE to the wall. This base station has a ubnt powerbeam (current generation)
The small router to the left is then stuck onto the poe injector ... It is a HapLite so that I can have the awesomeness power of Routerboard. The high power router to the right is a hight powered tplink router but only being used as a bridged AP. The cat 5 cable runs through the cieling to the other side of thr house. This is a WRN850HP.
