Remote Desktop Help Please
matrixkid
Kimberley
Hey guys. I seem to be having some trouble setting up a Remote Desktop.
I've downloaded and setup DynDNS. Checked if the ip with http://whatsmyipaddress.com but still getting errors when I try to connect,:(
I'm kinda new at this and not sure if I'm missing something or doing something wrong. Could somebody please help
Think you may need to be a bit more specific. Does the computer that you're remoting into have remote connections enabled?
Whats the error and how do you connect? We need just a little more info ;-)
Your router (if any) needs to foward port 3389 to the PC you're trying to Remote Desktop to.
Here's the error I get when i try to connect
Either the TS service is stopped, the network is down or the machine is off.
1) Does the PC have an external IP address, or is the router forwarding the port?
2) Does DynDNS Updater update the external IP on the dyndns server?
