Srack0verflow
question, if one was to make an extension with cat5; which two colours make up a pair? or will you have to strip back a piece and discard it to see/look?
your wireless does not sound like its setup properly tho maybe setting up the wireless properly could save you a heap of trouble
Cat 5 is a network cable... it looks like a telephone cable but has a wider plug and thicker cable
Its always better to run a cable, 20 is fine. If it goes outdoors then cover it with something to protect from the elements.
yup know that nowin short that yellow cable is a cat 5 Ethernet cable
it is properly setupi had nice signal until the south easter started to howl! and we have gigantic trees on the yard
the only thing i am not sure about is the channel setting... it was 11, i set it to 1, but looks like it must be something else???
Well I mentioned it must not be 1 or 11 try 6
yup know that now![]()
my original q is till will running a 20m dls line(rather) impact on speed and connectivity??
i did call 2c telecoms and they said that it wont
Well I mentioned it must not be 1 or 11 try 6 and I have huge trees here but havent noticed problems getting wireless from the carport which has trees in line of sight.
Goes through 3 walls in my house from router + veranda and manage 2 or 3 bars when using wireless N, but struggle using wireless G with 1 bar.
So sounds like you might be using wireless G then at 54 mbps.
Did you change the channel on the router in the other building? cause changing yours won't help if the other routers signal is being blocked.
1. Can you tell me what your pc says about the wireless signal by right clicking the wireless connection (looks like a computer) in the task bar on the bottom left of your screen. Tell me how many green bars it says for signal strength and the speed in mbps.
It Seems to me the easiest would be to put a splitter at the the telephone jack and then run an extension from there to where you want to place modem in your building
****s...me at work now but
1. ha ha ha hell ma jou signal moet omtrent bundu bash!
2. i will set the channel to 6
3. we only have the one telkom duoplus 300wr router
4. i have one bar
6. mbps i dont know not infront of laptop now will recheck after setting channel to 6 and also check bars
7. wireless G or N...where do i check that? how can i change it to N?
thank you for all the help so far!
you see the thing is i got it with the telkom 3 month free trial...not much i can do about some thing i got for free to try out...
my laptop is a bit old i was about to check the wifi specs myself and see if it is compatible with N....mecer EL 81 laptop
the best and cheapest way now is to lay a cable..which i will do myself cos i usually and am used to doing these things myself! ha ha haa![]()
Yep but still think about replacing the telkom junk. There is also windows updates which allowed my laptop to get wireless N instead of wireless G, but not sure if it works for the mecer EL 81 Laptop, but the wireless specs are same as mine so it is possible to get 150 mbps wireless N.
i will replace at the end of three months if i decide to continue with the package
for now i will ma do the cable thing then i dont have to woooory about wireless n and g and whatever else! ha ha haa
thanks so much
dalk het my vraag meer met jou thread te doen as wat jy dink. ag wel sterkte...boet moet nou nie my thread hi jack nie!google dit net....
btw the quickest way with least effort would be just to buy a ready-made phone extension and a splitter from checkers. i wouldn't want the router 20m away where i can't see the indicators
