Running dsl cable instead of using wireless question
no problem keep us posted on how it goes
i went home and changed the channel to 6....noooo change
i then took a screenshot of the status window with the mbps and bars
i see you get a 30m cable for R89.99 at hi-fi corp.. cheap enough
what you receiving from wireless is bad at 1 mbps it should be at least 11 mbps to get a good speed for internet access
R90 for 30 meters is not too bad or you can get a PC company to make the cable for you which is sometimes cheaper
at the telkom direct shop bought 20m for R39,99! all good now....well better than it was!
