SAMSUNG Auto Wall Mount
rpm
Admin
Staff member
Johannesburg
by: beemerstyle
Description: BRAND NEW SEALED IN THE BOX Have more than one favorite TV-viewing spot in your room? The motorized WMN-5090 wall mount lets you conveniently reposition your flat-panel Samsung TV for optimal viewing. The sturdy arm can swing the TV out from the wall at an angle of up to 20° and can also tilt it downwards up to 15° Use your Samsung TV remote to activate the arm and position your set. A provided cable connects the EX-LINK communications output on your Samsung TV to the mount and relays commands from your remote. You can program up to three different positions, so you can reorient the TV for one of your favorite spots with just the push of a button. And when you're done viewing, you can select auto-center to have the mount pull the TV flat against the wall. designed for Samsung flat-panel LCD TVs from 40" to 52" supports up to 110 lbs. swivel arm holds TV 2-1/2" to 9-1/2" from wall positioning control with memory for three positions and auto-center through Samsung TV remote and EX-LINK connection mounting hardware included tilt range: 0° to -15° down swivel range: up to 20° EX-LINK communications cable AC adapter stud-mounting required 26-13/16"W x 12-5/8"H x 3-1/4"D Features Overview: The WMN-5090AN allows you to mount a compatible Samsung Auto Mount-compatible flat-panel TV, and automatically adjust the viewing angle using the TV's remote control. It can swivel left and right up to 20°, and tilt up and down between 0° and -15°. Compatibility: The WMN-5090AN is compatible with 42" to 50" Samsung plasma TVs and 40" to 52" Samsung LCD TVs with the EX-Link connection (3.5mm minijack) on the rear panel. Installation: The wall plate is attached to the wall with ten 2" (50mm) screws (a total of 12 screws and wall anchors are supplied). The screws and anchors provided are for both wood and concrete surfaces. For marble and steel walls, appropriate specialized fasteners should be used. For plasterboard (drywall), you should locate the wood studs using a commercially-available stud finder, and attach the wall mount to the studs. The wall plate has a series of mounting holes spaced 8-3/16" apart vertically and a maximum of 26" apart horizontally. It is extremely important that the strength of the wall is checked before installation, and reinforced if necessary. Installing the TV: The two supplied hangers are for use with all but the 40" Samsung LCDs. These hangers are bolted to the back of the TV in the VESA 600x400 pattern, using the supplied M8 bolts. The TV is then hung on the wall mount's horizontal bars. The bar's end caps prevent the TV from sliding from side to side. The 40" Samsung LCD TVs have a VESA 200 (200mm x 200mm) bolt pattern. In order to mount these TVs, the wall mount's horizontal bars are removed, and the TV is directly bolted to the wall mount's VESA 200 mounting holes, using the supplied M6 bolts. Connections: There are two connections required during installation of the wall mount. The unit has a standard round 12V DC power input for use with the supplied AC adapter. The AC adapter comes with a plastic housing that allows you to mount the transformer on the wall mount bracket. In addition, the supplied communications cable (40" stereo miniplug cable) plugs into the "EX-Line" jack on the wall mount and the "EX-Link" jack on the TV. This connection feeds the remote control signals from the TV to the wall mount when adjustments are made. Note: You will need to make the connections to the TV in the order specified in the installation manual. Adjustment Features: The WMN-5090AN has several unique features: Silent Operation: The unit is equipped with a cutting-edge motor with no brush, designed to minimize noise. Auto Centering: With a press of a button, you can move the TV until it is as close to the wall as possible, even with the TV off. 3-Position Memory: The wall mount can memorize up to 3 specific positions, allowing you to move your TV to a memorized position with the press of a button. Auto Wall Detecting: Regardless of the size of the TV, the wall mount recognizes where the wall is and protects the TV from hitting the wall. Manual Operation: You can swivel or tilt the TV manually, if desired, rather than using the TV's remote control CONTACT WARREN 082 999 9559
