Setting up Billion Router using iMac
Sepeng
What's up all, wondering if anyone can help or point me to the right thread regarding my problem?
I've got an iMac connected to a Billion router (not sure the exact type, it seems to be a pretty standard one for home use) via cable. The router comes with a disk that installs software that allows you to change your router admin settings, internet usernames, wifi settings etc. This disk does not work on the iMac though, and every now and then my internet goes on the fritz and I have to change my settings from a guest account to get it back online. Right now I can't cos I don't have that software installed. How do I do this using the Mac, anyone know? Through Safari or something?
Thanks for any help.
Yes, generally through Safari. Go to System Preferences -> Network and check the address of the router there. Type that into Safari. You generally need to use a name and password, often both "admin" but check your manual for more info.
