Share 3G connection over wifi
jannievdberg
Amsterdam, The Netherlands
I have a 3G connection through a K3715 modem which I want to share over a wireless network using a WRT54GL router. modem is connected to my desktop as well as te router. I use Windows 7. any help will be appreciated.
Setup up Internet sharing (not sure on Win7) on your PC and then wireless devices connecting to the WRT54GL must use their gateway as your PC, Setup WRT54GL as an AP on the same IP address range as your PC .
I think that should work
Yes, this will work on win7, exactly the same as vista. So just go to network connections tab and enable internet connection sharing on the internet connection.
