Making the cheapest esp8266 based IoT relay possible without burning down my house. I'm currently on R40 a pop without enclosure or packaging. Trying to get it ready packed and shipped for R50 a unit.
I've had a side project for almost 2 years that I can't finishI go through months of no work, then try get as much as I can before time becomes an issue again...
She works at the office next door. Different company, same company. Didn't like me at all. Deliberately didn't laugh at my jokes. Very much an ice queen.
I helped her with some IT stuff a month ago. We ended up spending some time together while installs were going on. She realised I am not as shallow as I come across as.
Will likely pick up this ticket by the end of the year.
Reason why I am wary. Never **** where you eat. Can end badly
Some of mine.
Griblinks
http://www.techtinker.co.za/griblinks/ - Allows you to remotely control relays hooked up to a RPI, Can be controlled either via web browser or a mobile ap which I developed, still in beta stages haven't touched this for a while,
Geologic
http://www.techtinker.co.za/geologic/ allows you to use your cellphone as tracking device in your car, you can also set up Geo Fences that will send you a notification when pre-set beacons has been reached.
Offline. , Dont have a name for it yet, but I'ts a VB.NET app that will allow you to monitor a folder for PDFs which will automatically distribute Invoices to the correct customer, all it needs it a text field containing the email address and group when generated with your Favorite Report designer.
All of which ah Fo Freeee!![]()
She works at the office next door. Different company, same office block. Didn't like me at all. Deliberately didn't laugh at my jokes. Very much an ice queen.
Oh its quite a lengthy thing to explain, its token based, It makes use of the user's session, username and encrypted password to generate a token that's again encrypted (Like having a user account with username and 2 passwords) if the php session is different on each page to the stored key in the database it will kill all cookies and log the user out, something like that. I don't mind sharing the code if you are interested.
An Azure Webjob to monitor Takealot daily deals basically a console app running as a CRON job.
Telkom Mobile app for monitoring data usage.
Going to turn it into a web app. You register, provide your email address then when a deal matches your criteria you'll receive an email.That azure project sounds interesting. Going to blog about it soon?
Also looking into sending out a Whatsapp message but their 'API' is a bit tricky.
